Capture from a smartphone
A project log for Motion Capture system that you can build yourself
An open hardware-software framework based on inertial sensors that anyone can use to build a human motion capture system.
bruno-laurencichBruno Laurencich 09/12/2019 at 08:300 Comments
⚡ In the past months we were working on improving Chordata’s Remote Console, which allows you to capture data with in a much more easy way, even straight from your smartphone!
This improvement is something we’ve always desired, as Chordata is designed for both specialized users and beginners. With the Remote Console we’ll make the capture process simpler, thus allowing anyone to use our system easily!
Of course this is not a replacement for the "advanced" workflow, power users will still be able to access using tools as SSH.
Here's a demo of it's functionality:)
