First steps for the Keyboard controller
A project log for PIMP (Personal Information Manager & Pager)
A small MCU based PIM with Pager functionallity
WooDWorkeRWooDWorkeR 03/25/2018 at 21:560 Comments
A very important part of the PIMP project is the Keyboard. Without a keyboard, no notetaking capabilities.
The Blackberry Q10 keyboard has a basic keyboard matrix and needs 5 pins for the rows and 7 pins for columns.
The first iteration of this controller is build with an Arduino Nano. Later I may change to a cheaper Microcontroller like STM8, EFM8 or a SAMD10.
The Prototype
The firmware is pretty easy. Scanning the keyboard matrix, checking for button changes and then writing the pressed keys to the serial console. Of cause, there is a little bit "magic" in between to check if keypresses are actually printable characters. And because we can we also care for the keyboard backlight.
The Source
byte rows[] = {2,3,4,5,6,7,8};
const int rowCount = sizeof(rows)/sizeof(rows[0]);
byte cols[] = {A0, A1, A2, 12, 11};
const int colCount = sizeof(cols)/sizeof(cols[0]);
bool keys[colCount][rowCount];
bool lastValue[colCount][rowCount];
bool changedValue[colCount][rowCount];
char keyboard[colCount][rowCount];
char keyboard_symbol[colCount][rowCount];
int keyboardLightSteps = 20;
int keyboardLight = 20;
bool symbolSelected;
void setup() {
    keyboard[0][0] = 'q';
    keyboard[0][1] = 'w';
    keyboard[0][2] = NULL; // symbol
    keyboard[0][3] = 'a';
    keyboard[0][4] = NULL; // ALT
    keyboard[0][5] = ' ';
    keyboard[0][6] = NULL; // Mic
    keyboard[1][0] = 'e';
    keyboard[1][1] = 's';
    keyboard[1][2] = 'd';
    keyboard[1][3] = 'p';
    keyboard[1][4] = 'x';
    keyboard[1][5] = 'z';
    keyboard[1][6] = NULL; // Left Shift
    keyboard[2][0] = 'r';
    keyboard[2][1] = 'g';
    keyboard[2][2] = 't';
    keyboard[2][3] = NULL; // Right Shit
    keyboard[2][4] = 'v';
    keyboard[2][5] = 'c';
    keyboard[2][6] = 'f';
    keyboard[3][0] = 'u';
    keyboard[3][1] = 'h';
    keyboard[3][2] = 'y';
    keyboard[3][3] = NULL; // Enter
    keyboard[3][4] = 'b';
    keyboard[3][5] = 'n';
    keyboard[3][6] = 'j';
    keyboard[4][0] = 'o';
    keyboard[4][1] = 'l';
    keyboard[4][2] = 'i';
    keyboard[4][3] = NULL; // Backspace
    keyboard[4][4] = '$';
    keyboard[4][5] = 'm';
    keyboard[4][6] = 'k';
    keyboard_symbol[0][0] = '#';
    keyboard_symbol[0][1] = '1';
    keyboard_symbol[0][2] = NULL;
    keyboard_symbol[0][3] = '*';
    keyboard_symbol[0][4] = NULL;
    keyboard_symbol[0][5] = NULL;
    keyboard_symbol[0][6] = '0';
    keyboard_symbol[1][0] = '2';
    keyboard_symbol[1][1] = '4';
    keyboard_symbol[1][2] = '5';
    keyboard_symbol[1][3] = '@';
    keyboard_symbol[1][4] = '8';
    keyboard_symbol[1][5] = '7';
    keyboard_symbol[1][6] = NULL;
    keyboard_symbol[2][0] = '3';
    keyboard_symbol[2][1] = '/';
    keyboard_symbol[2][2] = '(';
    keyboard_symbol[2][3] = NULL;
    keyboard_symbol[2][4] = '?';
    keyboard_symbol[2][5] = '9';
    keyboard_symbol[2][6] = '6';
    keyboard_symbol[3][0] = '_';
    keyboard_symbol[3][1] = ':';
    keyboard_symbol[3][2] = ')';
    keyboard_symbol[3][3] = NULL;
    keyboard_symbol[3][4] = '!';
    keyboard_symbol[3][5] = ',';
    keyboard_symbol[3][6] = ';';
    keyboard_symbol[4][0] = '+';
    keyboard_symbol[4][1] = '"';
    keyboard_symbol[4][2] = '-';
    keyboard_symbol[4][3] = NULL;
    keyboard_symbol[4][4] = NULL;
    keyboard_symbol[4][5] = '.';
    keyboard_symbol[4][6] = '\'';
    Serial.begin(115200);
    for(int x=0; x<rowCount; x++) {
        Serial.print(rows[x]); Serial.println(" as input");
        pinMode(rows[x], INPUT);
    for (int x=0; x<colCount; x++) {
        Serial.print(cols[x]); Serial.println(" as input-pullup");
        pinMode(cols[x], INPUT_PULLUP);
    // set pins for the keyboard backlight
    pinMode(10, OUTPUT);
    pinMode(9, OUTPUT);
    setKeyboardBacklight(keyboardLight);
    symbolSelected = false;
void readMatrix() {
    int delayTime = 0;
    // iterate the columns
    for (int colIndex=0; colIndex < colCount; colIndex++) {
        // col: set to output to low
        byte curCol = cols[colIndex];
        pinMode(curCol, OUTPUT);
        digitalWrite(curCol, LOW);
        // row: interate through the rows
        for (int rowIndex=0; rowIndex < rowCount; rowIndex++) {
            byte rowCol = rows[rowIndex];
            pinMode(rowCol, INPUT_PULLUP);
            delay(1); // arduino is not fast enought to switch input/output modes so wait 1 ms
            bool buttonPressed = (digitalRead(rowCol) == LOW);
            keys[colIndex][rowIndex] = buttonPressed;
            if ((lastValue[colIndex][rowIndex] != buttonPressed)) {
              changedValue[colIndex][rowIndex] = true;
            } else {
              changedValue[colIndex][rowIndex] = false;
            lastValue[colIndex][rowIndex] = buttonPressed;
            pinMode(rowCol, INPUT);
        // disable the column
        pinMode(curCol, INPUT);
    if (keyPressed(0, 2)) {
      symbolSelected = true;
bool keyPressed(int colIndex, int rowIndex) {
  return changedValue[colIndex][rowIndex] && keys[colIndex][rowIndex] == true;
bool keyActive(int colIndex, int rowIndex) {
  return keys[colIndex][rowIndex] == true;
bool isPrintableKey(int colIndex, int rowIndex) {
  return keyboard_symbol[colIndex][rowIndex] != NULL || keyboard[colIndex][rowIndex] != NULL;
void setKeyboardBacklight(int keyboardLight) {
    analogWrite(10, keyboardLight);
    analogWrite(9, keyboardLight);
void printMatrix() {
          // we only want to print if the key is pressed and it is a printable character
          if (keyPressed(colIndex, rowIndex) && isPrintableKey(colIndex, rowIndex)) {
            String toPrint;
            if (symbolSelected) {
              toPrint = String(keyboard_symbol[colIndex][rowIndex]);
            } else {
              toPrint = String(keyboard[colIndex][rowIndex]);
            // keys 1,6 and 2,3 are Shift keys, so we want to upper case
            if (keyActive(1,6) || keyActive(2,3)) {
              toPrint.toUpperCase();
            Serial.print(toPrint);
// a helper method that checks boundaries for the PWM values
void changeBackgroundLight(int pwmValue) {
  if (pwmValue > 255) {
    pwmValue = 255;
  if (pwmValue < 0) {
    pwmValue = 0;
  keyboardLight = pwmValue;
void loop() {
    readMatrix();
    printMatrix();
    // key 3,3 is the enter key
    if (keyPressed(3,3)) {
      Serial.println();
    // increase backlight if symbol key is pressed
    if (keyPressed(0,2)) {
      changeBackgroundLight(keyboardLight + keyboardLightSteps);
    // decrease backlight if right shift key is pressed
    if (keyPressed(2,3)) {
      changeBackgroundLight(keyboardLight - keyboardLightSteps);
    delay(10);
