Power source - smoothing / basic regulating
A project log for Lab bench Supply
Build a simple power supply for diy projects
csiszr-attilaCsiszár Attila 09/29/2017 at 17:580 Comments
Next step is to make the rectified DC signal smoothed.  I watched a couple of videos about it, namely:
Also read about smoothing, voltage ripple, etc. but I still not got around my head about the correct way to calculate the smoothing capacitors.
Probably 2x 2200uF capacitor will be more than enough, but the biggest problem I don't have these high values in my stash so for the time being I can't test the circuit.
