Click click click
A project log for CNC MPG
Manual Pulse Generator (MPG) for a CNC machine
the.wretchthe.wretch 10/22/2017 at 18:040 Comments
Originally I was planning to use 32 magnets, giving me 128 pulses per revolution. I tried some test prints and came to the conclusion that this was a bit overkill, eventually I continued with 16.
To give some tactile feedback, I added a clicker that clicks on every quadrature step. The clicker consists of a (round) track of 64 shallow (0.4mm) pockets in the base plate and a 4mm spring loaded ball in the dial.
Base plate with clicker pockets
Top of the dial
Bottom of the dial
The clicker ball and spring
Clicker ball inserted
