Light-up LED Dress for Halloween
My niece wanted to be a princess for Halloween so I made her a light-up RGB LED dress
This is a RGB LED light-up dress I made for my niece for Halloween 2016 as she wanted to be a princess and I wanted to make her something magical. Nearly everyone who saw it while trick-or-treating had a reaction to it.
I used 5050 RGB LED strips, a simple 12VDC regulator, and Ryobi 18V cordless tools lithium ion battery to make the LED dress.
How-to article can be found on my website here: http://lukeskaff.com/diy-light-up-led-dress/
Video:
GIF: https://gfycat.com/DimwittedAncientDarwinsfox
  • 1 × White Dress
  • 1 × Petticoat / undershirt
  • 1 × 5050 RGB LED strip
  • 1 × IR RGB LED strip controller
  • 1 × Ryobi Powertool Battery
View all 6 components
  • 1
    Full build instructions are on my website
    Full LED Dress how-to instructions from my blog
  • 2
    LED Mounting
    The 5050 RGB LED strips are mounted to a peiticoat / underskirt to allow the dress to be washed, modular, and to "poof" out the dress for extra effect.  The LEDs are mounted facing inward to make a diffused glow and so the dress will not have point light sources.
  • 3
    Power supply
    For the power regular I used a super overkill cheap 240W step down buck power supply I found on amazon.  I wanted something fully enclosed, waterproof, low heat, for piece of mind against arcing or overheating.  There is probably a much better potted or fully enclosed low cost solution out there and would like to see what others recommend.  There are a ton of low cost buck regulators on ebay but I have not seen good options for ones that are potted.
View all 4 instructions
Radu Motisan wrote 10/31/2017 at 20:03 point
awesome, my little girl would love this too
Winston wrote 10/04/2017 at 13:43 point
I'm seeing multiple LED strip Halloween outfits and am hoping that people doing this are using inline fuses or some other overcurrent protection methods to prevent arcs/sparks and possible resulting garment fires from the low internal resistance batteries being used. Perhaps the Ryobi Powertool Battery has internal protection for that? I see others just using multi-cell lipos.
Luke Skaff wrote 10/04/2017 at 14:33 point
Winston, that is a good idea for a cheap added safety feature.  I will add a fast blow low current fuse after the power supply.
