No more hard coded flash drives and a unmount button
A project log for Night vision camera raspberry pi
A night vision camera built with a raspberry pi zero w, night vision camera plus a 3.2" screen
facelessloserfacelessloser 10/21/2017 at 18:260 Comments
So I finally got round to adding code so I can use any flash drive instead of hard coding in a set flash drive. Also added a un-mount on screen button with text to let you know if the drive is mounted or un-mounted. Also if a flash drive isn't mounted it will save the photos and videos to sd card.  Also added a on screen exit button so I can free up the 3rd button for a gif button in the future.
