Hackaday.io Hackaday.io
Recently Updated Most Likes Newest Project Lists
Courses Tutorials Events Hackerspaces Profiles Hackaday.com Tindie Marketplace
Sign up Log in
Help for blind people
with this project a blind person can orient himself
KoppendorferKoppendorfer
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
272 followers
  • Description
  • Details
  • Files 1
    • View all
  • Components 5
    • View all
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
272
0
272
1
Team (1)
  • KoppendorferKoppendorfer
Join this project's team
hardware
ongoing project
2017HackadayPrize
This project was created on 10/02/2017 and last updated 4 years ago.
Description
The connection between human and machine should be as simple as possible
With this project it is possible to simply transfer a scanned line to the human being, the most important part of this project is to transfer only the line and thereby keep the interface human-actuators as simple as possible.
By vibrating motors, this so-called line is projected onto the skin surface, so the person can imagine the environment.
The scanner is attached to the head so that the entire environment can be imaged by moving the head
Simple and cheap to build
It works quite well, only the software implementation would still have to be worked
Unfortunately, I have too little experience with programming
it would be nice if this project became a usable tool !!!
Thanks
Peter
Details
Files
servos2V2.ino
ino - 8.17 kB - 10/02/2017 at 08:49
Download
Components
  • 20 × LB1938H Micro DC Motor Low Voltage Driver Board DC2.2-10V
  • 20 × DC 3v~5v 24000rpm Wasserproof Mini Coreless vibration Motor Micro Vibrator
  • 1 × Arduino Mega
  • 1 × Mega Sensor Shield V2.0 V2 für Arduino Mega 2560 R3 1280 Servo Motor Stepper
  • 1 × RP-LIDAR: Low Cost 5hz 360 deg LIDAR ( I use the first version )
Log In/Sign up to comment
Sign up with Github
OR
The 2017 Hackaday Prize
Can we build a open source machine that can receive the dankest memes from the future?
Project Owner Contributor
Receiving Dank MEMES from the Future
Ricardo FerroRicardo Ferro
As a Christmas preparation I have buildt "Velleman MK100" Electronic Christmas Tree project.
Joe CornerJoe Corner
Small surface vessel
small surface vessel
jacobjacob
I have buildt "Velleman MK167" Electronic candle project.
Electronic candle
Going up?
© 2023 Hackaday
Yes, delete it Cancel
You are about to report the project "Help for blind people", please tell us the reason.
Send message
Remove Member
