Hackaday.io Hackaday.io
Sign up Log in
Omni wheel Infinity plotter
trying to invert dektop-plotter to build an infinty-plotter-bot
sven-jungclausSven Jungclaus
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
5 comments
6 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 3
    • View all
  • Instructions 0
  • Discussion 5
View Gallery
738
5
6
6
Team (1)
  • sven-jungclausSven Jungclaus
Join this project's team
hardware
ongoing project
CNC ROBOT plotter
This project was created on 10/02/2017 and last updated 7 years ago.
Project Logs
Collapse
  • Laser attached
    Sven Jungclaus • 03/01/2018 at 18:11 • 0 comments
  • just finished the mechanics
    Sven Jungclaus • 01/28/2018 at 08:38 • 0 comments
  • 1st wheel test
    Sven Jungclaus • 12/29/2017 at 17:34 • 0 comments
    1st wheel test...
View all 3 project logs
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
agp.cooper wrote 10/07/2017 at 08:14 • point
Okay I see you may be talking about a robot plotter (or tortoise) rather than plotting infinity.
Sven Jungclaus wrote 10/07/2017 at 12:06 • point
yep, now you are right... Just changed the headline to avoid more confiusion
agp.cooper wrote 10/07/2017 at 08:10 • point
Poincare's disk is a circle that plots an infinite distance.
You may know it from Escher's work (see http//mathworld.wolfram.com/images/eps-gif/HyperbolicTessellation_1000.gif).
agp.cooper wrote 10/06/2017 at 23:33 • point
"Poincare" disk?
Sven Jungclaus wrote 10/07/2017 at 05:03 • point
?what do you mean?
This is a test.
Project Owner Contributor
This is a test
victoriaVictoria
A full open source electronic lab
Yellow pitaya
sanpiSanpi
DoctorDre
This concept is a test.
Anticipate My Needs Personal Assistant
doctordreDoctorDre
test
alpha beta
shree-sureshShree Suresh
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Omni wheel Infinity plotter", please tell us the reason.
Send message
Remove Member
