trying to invert dektop-plotter to build an infinty-plotter-bot
1st wheel test...
View all 3 project logs
Okay I see you may be talking about a robot plotter (or tortoise) rather than plotting infinity.
yep, now you are right... Just changed the headline to avoid more confiusion
Poincare's disk is a circle that plots an infinite distance.You may know it from Escher's work (see http//mathworld.wolfram.com/images/eps-gif/HyperbolicTessellation_1000.gif).
"Poincare" disk?
?what do you mean?
Victoria
Central Space Alliance
Shree Suresh
DoctorDre
Yes, delete it Cancel
You are about to report the project "Omni wheel Infinity plotter", please tell us the reason.
