Got to work carving the head and upper body.
I started with polyethylene pipe insulation. The poly insulation is about 1/8th the cost, but nothing sticks to it very well, it's very stiff, and it has a much larger open-cell structure. The wire brush trick to make it look like wood also requires heating it afterwords to get it to look right. I didn't like the results so I scrapped it all and started over with neoprene.
Also ended up making panels from the softer neoprene pipe insulation for the head.
Gluing it to the spandex gave it a stable base so it didn't immediately tear. This allowed me to cut/sand it to shape nearly down to the fabric which gave the resulting mask really good flexibility.
It seems I originally forgot to post the following video, so here it is.
