• Using the YASSD
    riktw10/15/2017 at 07:40 0 comments
    The YASSD is controlled via a UART connection, via a couple of simple commands, at a baudrate of 19200:
    To control what is displayed:
    ID,NUMBER\n
    So if the display has an ID of 04 and you want to display 1337:
    04,1337\n
    A dot is no problem, just insert it whereever:
    04,1.234\n   or 04,123.4\n
    To change the brightness:
    ID,Bx, with x being 0 to F (hexadecimal 0-15) for the brightness, 0 being the lowest, F the highest, for example:
    04,B2\n  or 04,BA\n
    As long as YASSD boards have a different ID set by the solder jumbers, they can be connected to the same UART bus, a bit like how I2C works.
