I2C pull-up issue
A project log for I2C Encoder
Connect up to 16 encoders on Arduino or ESP8266 board on the I2C bus!
saimonSaimon 10/22/2017 at 09:380 Comments
Thanks to the community i found a problem on the i2c pull-up resistor.
When the P-UP jumper is open, the two resistors are in parallel to the SCL and SDA pins, which causes problem on the bus.
The solution is simply remove them when pull-up resistors are not used.
My appreciations to the hackaday community!
