Notes for the Next Version
A project log for µGame
A handheld game console programmable with (Micro/Circuit)Python.
dehipudeʃhipu 10/22/2017 at 10:493 Comments
I finished up the second PCB — added the switches, the battery charging, the speaker, and even added a LIR2032 battery on the back. I will be developing my sprite library now.
Of course the first (well, second, but first physical) prototype has a number of problems. I will write them down, so that I can fix them when I make the next version:
davedarko wrote 10/22/2017 at 11:35 point
"Mounting holes under the display make no sense" - I was wondering about that myself :D Do you have any expectations on battery time? I need to measure that myself at one point.
deʃhipu wrote 10/22/2017 at 11:41 point
Not really, I suspect the main use of the battery will be the backlight, which is about 40mA, and the battery is 40mAh... The piezo might be taking a lot too.
davedarko wrote 10/22/2017 at 12:33 point
well that I can calculate in my head :)
