Documentation and Tutorial
A project log for µGame
A handheld game console programmable with (Micro/Circuit)Python.
dehipudeʃhipu 01/28/2018 at 19:325 Comments
I finally finished writing the bouncing ball tutorial, and published the documentation. You can see it at http://ugame.readthedocs.io/en/latest/tutorial.html
It merely scratches the surface — I will need more documentation, in particular, I will need topic guides explaining some of the most useful techniques for writing the games. But this is at least a start.
davedarko wrote 02/09/2018 at 18:36 point
could you add the screw hole dimensions and distances etc? looking into printing something myself, once the 2nd battery is here. The first one came puffed (maybe due to weather)..
deʃhipu wrote 02/09/2018 at 18:37 point
I could publish an OpenScad model, I suppose? Would that help?
davedarko wrote 02/09/2018 at 18:58 point
I just wanna know where to put what screw size :) Seems like a 2.5mm hole.
deʃhipu wrote 02/10/2018 at 12:20 point
The hole is exactly 2.6mm in diameter, so M2.5 should work.
