Since there will undoubtedly be more than one of these SpaceBots! in operation, its logical that they should be aware of each other. This could be taken further, with a collaborative arrangement made between different SpaceBots!
Communications will probably be through cheap, readily available means in early phases, such as ISM-band transceivers or Bluetooth / BLE.
