WiLoader
WiLoader: The WiFi programmer for AVR and Arduino
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
WiLoader uses WiFi for programming & communication. It can connect to your existing WiFi network and even if the signal is too weak or not available, it’s capable of creating a WiFi network.
WiLoader makes programming easier and much more fun. Specially when you are dealing with robots, drones and other portable devices. It’s a suitable and wise choice for hard to access devices too.
WiLoader supports ATMega & ATTiny chips. It’s also compatible with AVR based Arduino boards and matches perfectly with their programming pins. So in short, it’s the new generation of programmers.
