Boards ordered!
A project log for DryerSignal
A simple signal when the dryer is done.
liebmanliebman 10/12/2017 at 20:580 Comments
    Redesigned to drop the voltage regulator and use 3 to 6 volts. Note that you can't 4 AA's as that will exceed ATTiny specs as they each start closer to 1.8v....  so 3 AA's it is!
   I designed and ordered via OshPark will continue when they arrive.
