DIY Laser Piano
I built a laser piano using LDRs and laser light diodes. I used an Arduino Leonardo Pro Micro connected to a speaker to generate sound
I built a laser piano using LDRs and laser light diodes. I used an Arduino Leonardo Pro Micro connected to a speaker to generate sound. There are five steps to make this project : First Step: Marking, Cutting and Gluing base Second Step: Inserting and attaching LDR and Laser diode in the cardboard Third Step: Soldering Making the Circuit Coding I have given rest of the details in the log.
I built a laser piano using LDRs and laser light diodes. I used an Arduino Leonardo Pro Micro connected to a speaker to generate sound. You can modify the tune of the piano by tweaking in the code and changing the frequency. I wanted to create something cool which can produce music and I ended up making this.
Instructions and code are given in the step. Enjoy.
I hope you like my tutorial on this laser piano. Subscribe to my YouTube channel for more tutorials like this.
My Social Profile Links:
Circuit Diagram and Schematic
Portable Network Graphics (PNG) - 388.36 kB - 10/11/2017 at 10:00
Preview
  • 8 × LDR Resistor Networks / Thick Film Networks
  • 8 × laser diode
  • 1 × Arduino pro micro
  • 1 × 8 Ohm Speaker
  • 1 × USB Cable
  • 1
    Making the base and structure of piano
    The base is made up of lot of cardboard ad glue gun. I have given the details along with the dimension in the image. Also make sure you are choosing the right kind of cardboard for making it.
  • 2
  • 3
View all 5 instructions
