Hackaday.io Hackaday.io
Sign up Log in
YaRC Vehicle V3
A rover with camera feed via RPi, radio link via Wifibroadcast, telemetry feed, custom PCB's and laptop as control station.
welters-hackzWelters Hackz
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
15 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
827
0
15
12
Team (1)
  • welters-hackzWelters Hackz
Join this project's team
completed project
hardware
teensy raspberrypi pcb Wifibroadcast rover
This project was created on 10/13/2017 and last updated 8 years ago.
Description
This is the natural evolution of my first rover project. The software is essentially unchanged. This project is focused more on hardware: The rover sports a commercial rock climber chassis, an upgraded Raspberry Pi - now version 3 - and self-designed PCBs comprising an H-Bridge from discrete components as well as various connectors for servos, voltage converters, a Teensy board and so on. The camera pole was upgraded with a yaw-servo and a new camera module bearing a wide angle lens.
Details
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
In this project, I’m exploring a simple approach to mapping vegetation and open spaces: using a rotating camera on a post.
Project Owner Contributor
Rotating Camera for Vegetation Mapping
florian-ellserFlorian Ellsäßer
This project describes how i hacked Raspberry pi Camera and get 4 MIPI CSI-2 Lanes data out of it
Hacking Raspberry PI Camera V2 4 Lane MIPI CSI-2
gaurav-singhGaurav Singh
Tracking drones in infrared
Open Light Motion
aeracoopAeracoop
The idea of the project is to convert my normal CCTV camera into smart system using the power of OpenCv and Raspbery Pi as the base hardware
Normal CCTC gets Smart using OpenCV and Rasp. Pi
aswinth-rajAswinth Raj
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "YaRC Vehicle V3", please tell us the reason.
Send message
Remove Member
