Nplus_toeguard_v2.stlUpdated lower profile toe guardStandard Tesselated Geometry - 825.86 kB - 11/27/2017 at 02:14 |
Standard Tesselated Geometry - 18.01 MB - 11/07/2017 at 08:33 |
Standard Tesselated Geometry - 45.28 MB - 11/07/2017 at 08:25 |
Standard Tesselated Geometry - 4.13 MB - 11/07/2017 at 08:24 |
Standard Tesselated Geometry - 4.89 MB - 11/07/2017 at 08:24 |
Nplus_toeguard.stlV1 tall toe guardStandard Tesselated Geometry - 2.23 MB - 11/07/2017 at 08:24 |
Standard Tesselated Geometry - 2.32 MB - 11/07/2017 at 08:24 |
Standard Tesselated Geometry - 1.87 MB - 11/07/2017 at 08:24 |
Standard Tesselated Geometry - 920.98 kB - 11/07/2017 at 08:24 |
Standard Tesselated Geometry - 2.63 MB - 11/07/2017 at 08:24 |
Platform.f3dPrint from TPUf3d - 2.03 MB - 10/21/2017 at 10:14 |
Clipless.f3dRigid material (not sure if it will be strong enough)f3d - 1.44 MB - 10/21/2017 at 10:14 |
Insert Nubs.stlThese insert nubs are encased between layers of carbon in the core. (with McMaster 3mm insert #94180A331)Standard Tesselated Geometry - 778.50 kB - 10/21/2017 at 09:20 |
Toeguard Insert.f3dPrint from tough material, modify for add protection to toe.f3d - 939.43 kB - 10/16/2017 at 09:09 |
Heel Rubber.f3dPrint from TPU (like Cheetah) Size US 10f3d - 6.22 MB - 10/16/2017 at 09:07 |
Toe.f3dPrint from TPU (like Cheetah) Size US 10f3d - 11.67 MB - 10/16/2017 at 09:00 |
Core.f3dMake out of carbon using mold.f3d - 3.17 MB - 10/16/2017 at 08:50 |
MidHeel.f3dPrint from rigid like ASA or PC Size US 10f3d - 4.35 MB - 10/16/2017 at 08:46 |
MidToe.f3dPrint with tough flexible like Taulman PCTPEf3d - 3.58 MB - 10/16/2017 at 08:46 |
CoreLayers.pdfCut pattern for core layupAdobe Portable Document Format - 741.01 kB - 10/16/2017 at 08:31 |
barend.f3dPrint in TPUf3d - 95.66 kB - 10/16/2017 at 07:54 |
barend_USB.f3dPrint in TPU. Bar end holds Verbatim Clip-It USBf3d - 96.80 kB - 10/16/2017 at 07:54 |
N+ Core Insert Drawing.pdfTechnical drawing of coreAdobe Portable Document Format - 234.16 kB - 10/16/2017 at 07:53 |
Marcs_research.pdfA research report submitted as my final bachelors project.Adobe Portable Document Format - 5.48 MB - 10/16/2017 at 07:13 |
Nplus_textile_v1.aiSimple textile pattern for shoe uppers. Modify according to available materials.postscript - 1.55 MB - 10/16/2017 at 06:45 |
