Scout monitoring system
Complete off-the-grid radio tracking network with online map service
The Scout monitoring project was launched to create a tracking network for a scout competition taking place in September 2017. A few radio, electronics and programming enthusiasts created a complete system from scratch that tracked GPS position of individual scouts in forests, carried the information through a network of base stations, uploaded data to a self-crafted web service and ultimately visualized the data on a map service in real time. The radio network itself was independent of mobile networks and managed to track scouts where no mobile network coverage existed.
Problem: Scouts can be lost into forest and not easily found upon competitions. Orienteering in darkness and under adverse conditions is not easy. This was demonstrated in the competition we tracked: a handful of scouts got lost and needed SAR.
Solution: We created a radio tracking network for scouts. The scouts can be tracked in real time on a map system and SAR operators can be coordinated accordingly.
We were able to change the way the competition status is monitored. We were able to see when the scout teams arrive to checkpoints and give an early warning to the checkpoint operators to prepare or to disassemble when every team had passed the checkpoint. On top of that, we were able to speed up the rescuing process if a team got lost. Finding a lost team from a 1x2km area in darkness and rain is not an easy task - unless you know the exact position.
The project can change the world. If more events employ live tracking, the events can be safer and much more educative - the team can see afterwards where they have been. The teams can truly learn from their mistakes.
Licensing during the project: most of the software can be licensed under MIT or GPL and on some occassions, GPL applies.
tb-ka.sch
Schematic of a base station (Eagle)
sch - 694.62 kB - 10/16/2017 at 19:12
Download
tb-ka.brd
Board file of a base station (Eagle)
brd - 299.69 kB - 10/16/2017 at 19:12
Download
tb-ka.schematic.pdf
Schematic
Adobe Portable Document Format - 174.05 kB - 10/16/2017 at 19:12
Preview
tb-ka.board.pdf
Board
Adobe Portable Document Format - 65.14 kB - 10/16/2017 at 19:12
Preview
  • In operation: what was achieved
    Mikko L • 10/16/2017 at 19:39 • 0 comments
    The scout competition launched on 16th September in Southern Finland. It was an early morning when 37 trackers were distributed to the teams to be sent to deep forests. It was clear in the beginning that the most will stay in the forest even when it was dark and having to manage on their own.
    With the exception.
    We as the organizers of the competition had a direct insight to their position. We were able to estimate when they were getting "too" lost and were able to deploy a search-and-rescue team. A few times this was really needed.
  • Tracker device
    Mikko L • 10/16/2017 at 19:31 • 0 comments
    The tracker devices are rougly the size of a handheld radio and can operate on a battery for one day. Their main parts are a GPS receiver, a VHF data transceiver with a microcontroller, a flash memory to store location data and a battery charging circuit.
    So far there have been 3 revisions of the tracker design including a very early prototype with a slightly different design. The very first tracker was crafted as a course exercise in Aalto University, School of Electrical Engineering, course Electronics Workshop (Elektroniikkapaja). The first prototype was a success with good-enough performance, based on which the second revision was designed.
    The second revision (PB, as we call it) was based on a 32-bit ARM µC compared to the AVR in the PA revision. The radio part was integrated in the µC (EFR32FG1P131F256GM) and therefore the BOM actually decreased from the first revision. However, the PB came with some limitations, such as no power switchs for peripherals, and was surpassed by the production model PC.
    The PC revision was designed in great hurry, since the competition was close. The ultimate design was sent for manufacturing in the end of July, only 1,5 months before the competition. The revision was success, however, and we managed to prepare 50 trackers for operations just in time. Literally - the last changes were made only days before the competition.
    A fun detail: the tracker is protected by an ammunition pouch with PALS straps intended for military operations. However, the cartridges are now replaced by GPS tracking. The pouches were readily available at reasonable prices and were surplus.
  • Web service for tracking
    Mikko L • 10/16/2017 at 19:23 • 0 comments
    We had data from the radio network, but the system to visualize the data was missing. One of our team members took an appointment and created one from scratch.
    The online system consists of a PostGIS database to store the incoming packets and an Openlayers engine in the front to visualize all in the browser.
    The project began in March 2017 and required numerous weekends of 100% programming with extraordinary attention to detail and the big picture in the same time.
    The result was astonishing. The system received position reports as $POS messages (format created during the project), saved the data and updated it in real time on the map. The system was deemed stable enough to be ready for production.
  • Base stations
    Mikko L • 10/16/2017 at 19:19 • 0 comments
    The network consists of multiple battery powered base stations and a single central controller that has an Internet connection. All of the base stations receive location data from trackers on VHF and have an UHF link radio for communication between base stations. The network is able to relay data from remote base stations through multiple hops so that all the location data is eventually received by the central node and sent to a web server.
    Both the VHF and UHF parts use radio hardware and communication protocols specifically designed for needs of the system. New protocol designs are being planned to increase capacity to handle more trackers and to increase range of the radio links. Some parts of the current and future radio systems could possibly be used for other IoT, M2M and sensor network applications as well.
    The schematics and board layouts have been attached to the project entry.
View all 4 project logs
steve wrote 05/16/2018 at 08:55 • point
Great to see the collaboration between so many individuals and groups to solve a problem.  If anyone is interested in something similar using off-the-shelf hardware and software, and completely off-grid tracking/mapping (no internet access needed), have a look at my project that has many of the same features, yet admittedly not as refined as this project:
https://hackaday.io/project/13013-off-grid-gps-race-tracker-client-and-server
2FTG wrote 10/16/2017 at 21:20 • point
Debugging the PB and PC trackers right before the Sept16 was quite something. Way too much days where after work folks would arrive at the club to wrangle with the trackers and leave late at night.
