A more complex design for the indoor version
A project log for Window on the world
Screens in the streets and in art centers to make video exchanges between cities
pixjuanPixJuan 04/22/2018 at 05:250 Comments
A simple screen can be a bit dull, so how can it be made fancier? I like the idea of a door, so let's add :
How it would work
Your door, A is connected to a single other door B
When you knock on your door A
Using the peephole
I like the idea of a peephole but I'm not sure how to make it interesting without being too invading for the privacy.
It will probably display a static image or a looping video of the other side, a bit like a profile picture, so you can know what to expect before you knock the door.
I don't know how to display the image, I can either add a 1" OLED screen inside the door, of I can just make a real hole in the door, add lenses, and a sensor so that when someone takes a peek, it switches on the screen and display an image on the part which is just in front of the peephole, this way of doing is a bit more hackerish ;-)
Half skype, half chatroulette
In the original concept case the connectivity is simple a door A is always linked to a door B. But we can imagine a more dynamic connectivity where, when a user knock on a door a requests is sent on a server to find a peer. Or you can make other rules like "a door opened in a museum will always open on a door located in another museum, a door in your hackerspace will always open on a door in another hackerspace" etc.
You could also put restrictions on the language used, and for example only request Spanish speaking door if the door is located in your Spanish language exchange club, etc.
But honestly this feature would only make sense if hundreds of "doors" are in use, or if there is a software version, let's focus on something more realistic first ;-)
Illustration
