RadioHead RF95 Driver / Low Data Rate Optimization
A project log for ESP32 - LoRa - OLED Module
Get the most out of your (heltec/ttgo/aliexpress) ESP32 LoRa OLED development board
datadata 10/24/2017 at 03:282 Comments
Digging somewhat deeper into the RadioHead driver, I noticed an issue with the predefined ModemConfiguration parameters. The third configuration register (0x26) is always 0x00. This is, how they are defined in RH_RF95.cpp:
PROGMEM static const RH_RF95::ModemConfig MODEM_CONFIG_TABLE[] =
    //  1d,     1e,      26
    { 0x72,   0x74,    0x00}, // Bw125Cr45Sf128 (the chip default)
    { 0x92,   0x74,    0x00}, // Bw500Cr45Sf128
    { 0x48,   0x94,    0x00}, // Bw31_25Cr48Sf512
    { 0x78,   0xc4,    0x00}, // Bw125Cr48Sf4096
Now, I found in the SX127x application note ( http://www.semtech.com/images/datasheet/an1200.24.pdf ) that the third register 0x26 has two functions: AGC and Low Data Rate Optimization. The later being mandatory for spreading factors >= 11
So for a Sf of 11 (2048) or 12 (4096), it should be set. The predefined configuration for Bw 125kHz, Cr 4/8 with Sf 4096 should actually read    { 0x78, 0xc4, 0x08 }
Also keep this in mind when creating your own configuration parameters.
Mike wrote 02/06/2018 at 17:38 point
The semtech link is unfortunately broken. So I'm not sure if we are looking at the same document.
I found  https://www.semtech.com/uploads/documents/sx1272.pdf
But in there the description of register location 0x26 is "Reserved" when in LoRa mode.
So I don't know why Radiohead even bothers with it.
The setting you were concerned with, LowDataRateOptimize is bit 0 of 0x1D.
-Mike
data wrote 10/25/2017 at 21:08 point
[update}
Having posted this issue to Mike McCauley, maintainer of the RadioHead library, it will be addressed soon...
