svf - 667.94 kB - 11/26/2017 at 12:27 |
Simple_NX4_11_25.svfSame as "Simple_NX4_11_25.bit" in SVF format; works for me (richaplin); can boot a tile into r,g,b all row display. Although built from same src this SVF file is not quite the same as the one Spacecoaster posted. Give it a shot.svf - 667.94 kB - 11/26/2017 at 05:15 |
Simple_NX4_11_25.bitSame program as posted by SpaceCoaster on github "simple_nx4_8eab499.svf" but as a .bit file, compiled independently by rich aplin, confirm it works the same for me as him - I can power up my tile, load this .bit, and get all rows showing sequential r,g,bbit - 165.34 kB - 11/26/2017 at 05:05 |
simple_nx4_8eab499.svfSVF for programming simple_nx4. Displays vertical BRG stripes.svf - 665.18 kB - 11/24/2017 at 21:39 |
NX-4_CPLD_Startup_1.srA sigrok / PulseView compatible logic readout of the first data burst present on the CPLD-FPGA communication pins as the module starts up.sr - 4.48 kB - 11/24/2017 at 19:32 |
JunkCodePsychedelicLight.zipThis is a garbage project snapshot of when I first got lights. Some random thing in this is enabling the LED drivers. For {reason} you need to run this after first powering on the tile. Let's figure out what it is!x-zip-compressed - 990.10 kB - 11/15/2017 at 22:26 |
EEPROM_Control_RichAplin_1.binmay have errors, was dumped with hacky rigoctet-stream - 64.00 kB - 11/11/2017 at 06:23 |
EEPROM_Panel_RichAplin_1.binmay have errors, was dumped with hacky rigoctet-stream - 64.00 kB - 11/11/2017 at 06:23 |
Parallel_flash_dump.binThe 2MByte flash dumped. Not certain the address lines are correct but it looks reasonable. Of note; some strings at 0x110eb0, also some obvious 8bit->12bit lookup tables at 0x112000, 0x112400 . Note that this FPGA uses a bitstream that is 0x29500 bytes (1,353,728 bits) long, and there's a clear break in the flash contents at that point.See https://www.xilinx.com/support/documentation/user_guides/ug332.pdf for details on the data format- page 249 lists the bitstream bootstrap sync word of "0xAA995566" which is present at offset 4 in the flash. Possibly this image is off by 4 bytes, or maybe that's just how it is. octet-stream - 2.00 MB - 11/11/2017 at 05:23 |
EEPROM_Control_Mike_1.binEEPROM dump, control board, Mike's sample #1octet-stream - 64.00 kB - 11/03/2017 at 02:54 |
EEPROM_Panel_Mike_1.binEEPROM dump, LED panel, Mike's sample #1octet-stream - 64.00 kB - 11/03/2017 at 02:54 |
NX4_Pins_10-31-17.ucfpin constraintsucf - 2.81 kB - 10/31/2017 at 22:10 |
Simple_led_pattern_no_rowmux_yet.svfsvf file (equivalent to .bit file) load with a variety of toolssvf - 667.94 kB - 10/31/2017 at 22:09 |
Simple_led_pattern_no_rowmux_yet.bit.bit file load with xilinx tools or xc3prog linux toolbit - 165.34 kB - 10/31/2017 at 22:07 |
NX Rental installation.pdfInstallation and configuration document for Barco NX rental systems. Contains some useful information on setup and error codes.Adobe Portable Document Format - 21.22 MB - 10/26/2017 at 05:39 |
NX-4 System Specifications.pdfData brief for a NX-4 display tile, and overall performance specifications.Adobe Portable Document Format - 1.03 MB - 11/02/2017 at 05:18 |
