Cover Unoptimized.svg
This is a first cut of a file to be used to cut the cover on Ponoko. This file should not be used to make the cover, it needs clean up, but its a place holder. To use this file the stroke width need to be set to 0.01mm and the fill needs to be removed.
svg+xml - 640.54 kB - 10/22/2017 at 19:56
Preview
1/4 20 threaded rod with a flat ground on one end.<br>1/4 20 coupling nut with taped holes for set screws
JPEG Image - 48.29 kB - 10/22/2017 at 14:53
Preview
