Library test with cli NPM
A project log for Kibitech
The Personal Robot
judlup-lunaJudLup Luna 12/15/2017 at 05:110 Comments
Hi guys, we has working in library develop to communication between "brain" and nodes , for It we decided to make a example to understand how to make a library practical and robust, we development this library, is a calculator function, but the most important of It is the ".bin" function, when you install this library on your terminal can run owner commands.
You don't believe that this is all, not, we already have developed the library to end-node communicate with "brain" in both senses, this lib is called Kospr Cli, now, with ".bin" mode to develop learned we will go to work in develop the brain base system, we are very happy for this advances.
For the last, the NRF24L01P communication continous yet with us, only that we will goes to generate a "drive" for severals communications technologies :)
Greetings!
GitHubNPM Module
