First program file
10/26/2017 at 01:27 • 0 commentsUploaded first program file. This file is prototype software to be loaded onto the Arduino that will be in the box. This code uses momentary pushbuttons to test whether unlock conditions have been met. After these buttons have been pressed the program waits for an object to come within 5cm of the sonar. Once this is achieved the program stops, and lights an LED informing you that all unlock conditions have been met, then resets. This code will be updated as the design evolves.
