SmartPortInverterSOT23-6.zipA ZIP file for a version of the PCB using the DMN601DMK, which contains two MOSFETs in a single SOT23-6. This PCB has been checked for design rule violations and schematic connectivity -- it is free of errors. It has also been successfully uploaded to OSH Park. But it has not been fabricated. This PCB isa 2 layer board of0.33 x 0.33 inches (8.4 x 8.4mm) 3 boards will cost $0.50Zip Archive - 4.86 kB - 07/30/2018 at 13:21 |
SmartPortInverter1s.zipA ZIP file for a single sided version of the PCB. This PCB has been checked for design rule violations and schematic connectivity -- it is free of errors. It has also been successfully uploaded to OSH Park. But it has not been fabricated. This PCB isa 2 layer board of 0.37 x 0.38 inches (9.4 x 9.7mm) 3 boards will cost $0.70Zip Archive - 5.51 kB - 07/30/2018 at 13:13 |
SmartPortInverter.zipThis is the ZIP file that I uploaded to OSH Part to fabricate the PCB. This is such a small PCB -- it only cost $0.50 to build 3 prototypes with free shipping!!!Zip Archive - 5.70 kB - 10/31/2017 at 21:51 |
