Wurth_LTSpice_model.JPGFrom the instructions that come with their model. This is for a different transformer than the one I used, so the values will be different.JPEG Image - 40.20 kB - 11/11/2017 at 22:07 |
HVPS_SMD.csvBill of Materials - includes DigiKey part numbers.Comma-Separated Values - 997.00 bytes - 11/10/2017 at 01:28 |
Boost converter chips.xlsxController chips I examined for use in the project. See the logs for deciding factors.sheet - 36.66 kB - 10/29/2017 at 18:09 |
