The Timer
The MT7688 has a timer but I cannot find documentation how to access it (even if that is appropriate). So I have written a simple timer (uTime.c) using <signal.h> and <sys/time.h>:
#include <signal.h>
#include <stdio.h>
#include <string.h>
#include <sys/time.h>
void timer_handler (int signum) {
static int count = 0;
printf ("timer expired %d times\n", ++count);
int main () {
struct sigaction sa;
struct itimerval timer;
// Install timer_handler as the signal handler for SIGVTALRM
memset(&sa, 0, sizeof(sa));
sa.sa_handler = &timer_handler;
sigaction (SIGVTALRM, &sa, NULL);
// Configure the timer to expire after 1 second
timer.it_value.tv_sec = 1;
timer.it_value.tv_usec = 0;
// and every 1 second after that
timer.it_interval.tv_sec = 1;
timer.it_interval.tv_usec = 0;
// Start a virtual timer
// It counts down whenever this process is executing
setitimer (ITIMER_VIRTUAL, &timer, NULL);
// Do something that can be interrupted
while (1);
The code should be good for microsecond timing but I have not tested it.
Example Run
alanx@alanx ~/LinkIt-cc/uTimer $ make
/home/alanx/LinkIt-cc/toolchain-mipsel_24kec+dsp_gcc-4.8-linaro_uClibc-0.9.33.2/bin/mipsel-openwrt-linux-uclibc-gcc -I. -I/home/alanx/LinkIt-cc/toolchain-mipsel_24kec+dsp_gcc-4.8-linaro_uClibc-0.9.33.2/usr/include -I/home/alanx/LinkIt-cc/toolchain-mipsel_24kec+dsp_gcc-4.8-linaro_uClibc-0.9.33.2/include -o uTimer.run uTimer.c -L. -L/home/alanx/LinkIt-cc/toolchain-mipsel_24kec+dsp_gcc-4.8-linaro_uClibc-0.9.33.2/usr/lib -L/home/alanx/LinkIt-cc/toolchain-mipsel_24kec+dsp_gcc-4.8-linaro_uClibc-0.9.33.2/lib -lmraa -pthread -ldl
alanx@alanx ~/LinkIt-cc/uTimer $ ls -lah
total 28K
drwxrwxr-x 2 alanx alanx 4.0K Oct 29 09:53 .
drwxr-xr-x 8 alanx alanx 4.0K Oct 29 09:02 ..
-rw-rw-r-- 1 alanx alanx 829 Oct 29 09:03 Makefile
-rw-rw-r-- 1 alanx alanx 295 Oct 29 09:11 uTimer01.c
-rw-rw-r-- 1 alanx alanx 972 Oct 29 09:49 uTimer.c
-rwxrwxr-x 1 alanx alanx 7.4K Oct 29 09:53 uTimer.run
alanx@alanx ~/LinkIt-cc/uTimer $ scp uTimer.run root@mylinkit.local:~/Code/uTimer
root@mylinkit.local's password:
uTimer.run 100% 7534 7.4KB/s 00:00
alanx@alanx ~/LinkIt-cc/uTimer $ ssh root@mylinkit.local
BusyBox v1.23.2 (2015-11-18 16:34:33 CET) built-in shell (ash)
_______ ________ __
| |.-----.-----.-----.| | | |.----.| |_
| - || _ | -__| || | | || _|| _|
|_______|| __|_____|__|__||________||__| |____|
|__| W I R E L E S S F R E E D O M
CHAOS CALMER (15.05+linkit, r47501)
* 1 1/2 oz Gin Shake with a glassful
* 1/4 oz Triple Sec of broken ice and pour
* 3/4 oz Lime Juice unstrained into a goblet.
* 1 1/2 oz Orange Juice
* 1 tsp. Grenadine Syrup
root@mylinkit:~# cd Code/uTimer
root@mylinkit:~/Code/uTimer# ls -lah
drwxr-xr-x 2 root root 4.0K Oct 29 01:54 .
drwxr-xr-x 6 root root 4.0K Oct 29 01:52 ..
-rwxr-xr-x 1 root root 7.4K Oct 29 01:54 uTimer.run
root@mylinkit:~/Code/uTimer# ./uTimer.run
timer expired 1 times
timer expired 2 times
timer expired 3 times
timer expired 4 times
timer expired 5 times
timer expired 6 times
timer expired 7 times
^C
root@mylinkit:~/Code/uTimer# exit
Connection to mylinkit.local closed.
AlanX
agp.cooper
