Two days running
A project log for IOT Air Compressor
ESP8266 Based air compressor controller with WiFi.
boris-van-galvinBoris van Galvin 11/04/2017 at 07:590 Comments
two days in and its running a treat so far. dropped the pressure down to 50psi and the trigger to 10psi and the air leaks that are in the line (something i really should fix one day) causes the pressure to drop and the pump to start every 5 or so hours. Pump runs for a few seconds to bring the pressure back up to 50psi then shuts off.
