1# Measurements and menu system
A project log for Smart Thermostat
Home automation center, in a thermostat form.
mt-tthMáté Tóth 11/08/2017 at 19:091 Comment
I am working on the sensor placing, but I have a problem with thermal dissapation from the display and the mega, so I can not place the HTU21 sensor too close to the casing, because it will measuring higher themperature then it shoud have to.
The other which I am thinking of what I really like to see in the menu. I figured out, I will need 6 button or menu lap for the main menu, which will be:
  1. Time
  2. Graphs
  3. Web
  4. Setting themperature limit
  5. Paint / note, because I would like to leave messages on the screen if it needed.
  6. A Back button to return to the main screen. It will be the screen where you can see temp and humidity.
Some more picture:
I already have an lowe level menu, where I can go to the menu selector and back to the main screen.
I will write about the status of the project soon again.
maderasaus wrote 03/04/2020 at 15:14 point
I am glad that you have shared this post. Many people face a lot of issues regarding sensors and the reason is probably that they don’t think indicatively and now I'm able to check https://my-assignment.help/cheap-assignment-help-australia/ to get best assignment services. By your post one gets a lot of new ideas for resolving their minor issues.
