Biconical dipole antenna & IKEA cones
In case you like to play with your SDR like LimeSDR or SDRPlay you may need wideband reference antenna. 700 MHz to 2 GHz useful range.
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
663 to 1865 MHz SWR is less than 2.5:1 , Best SWR 1.37:1 at 1025 MHz , cones 122 mm / IKEA BLANDA BLANK 300.814.67 Second and third pictures you can see antenna in use on SDRPlayRSP1 x 2 both receiving on 1,8 GHz. Top signal is biconical dipole, bottom is 1/4 lambda for 1,05 GHz
