Hackaday.io Hackaday.io
Sign up Log in
esp32-wifi-manager
esp32-wifi-manager is an esp32 program that enables easy management of wifi networks through a web application.
tonyTony
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
9.5k views
4 comments
48 followers
  • Description
  • Details
  • Files 0
  • Components 1
    • View all
  • Logs 0
  • Instructions 0
  • Discussion 4
View Gallery
9.5k
4
48
27
Team (4)
  • tonyTony
  • channabasappakbchannabasappa.kb
  • dayvsonleandrodayvsonleandro
  • juanJuan
Join this project's team
  • source code
  • personal page
Software
completed project
ESP32 wifi ESP-IDF
Related lists
ESP32
proyectos con esp32
This project is submitted for
  • Hackaday.com Tip Line
This project was created on 11/11/2017 and last updated 4 years ago.
Description
esp32-wifi-manager is a pure C esp-idf component for ESP32 that enables easy management of wifi networks through a web portal. esp32-wifi-manager is is an all in one wifi scanner, http server & dns daemon living in the least amount of RAM possible. esp32-wifi-manager will automatically attempt to re-connect to a previously saved network on boot, and if it cannot find a saved wifi it will start its own access point through which you can manage and connect to wifi networks. Check out the readme at github to get you up and running with the software!
Details
Components
  • 1 × esp-idf Espressif SDK
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
discapacidad5 wrote 12/04/2021 at 20:23 • point
help me to develop low-cost braille display
Of 40 million blind people in the world, only 10% can read and write braille.
One of the primary reason for this is because braille hasn't yet found its jogging in the digital era, due to the sheer cost of such devices, as well as the affordability matrix of the visually impaired.
Low-cost braille displays have been sought after for quite a while with no avail.
Commercially available braille displays employ peizo-electric actuated pins, which are very expensive.
Due to the sheer expense of braille technology, and the scarce availability of books in braille, the medium is slowly falling out of favor. But many agree that braille literacy is paramount for the empowerment of the blind for education and employment.
It's amazing how expensive assistive technology is. A small flagil braille display costs more than $ 1,200 USD and a good quality one goes from $ 3,000 to $ 6,000. That is why I am developing an open source project. This is by no means a finished product. Being an open source project, I hope others will improve the design. In the near future, with the help of volunteers, Brailletouch will reduce the cost of a braille display by 90% and allow anyone who is visually impaired or deafblind to read and write braille, as well as use a computer or mobile device efficiently. and without noise. So if you know someone, if you are a creator, if you are curious or if you want to help, feel free to enter our repository https://github.com/brailletouch/Brailletouch and help me build a community around Brailletouch.
The encoder is practically the heart of the braille display. Most commercial braille displays have 40 or 80 braille cells. Since the most expensive on a braille display is braille cells, which cost more than $ 35 each, we are designing a new form of braille display with 40 virtual cells and a single physical braille cell, reducing most of the cost. . We are talking about a braille cell that can be made from 3D printed parts, I designed a different system. Instead of activating 40 cells at the same time and applying all the power to 40 physical cells, Brailletouch uses a physical encoder and a virtual braille display of 40 touch sensors placed in a matrix. In this way, the braille text is gradually displayed in a single braille cell as the virtual cells are touched. Parts can be easily printed.
My braille display design succeeds in reducing the cost of a braille display by over 90%. Currently, a braille screen has a cost between $ 1200 and $ 6000, being $ 1200 the smallest and most fragile, my proposal seeks to achieve a braille screen that can be manufactured between 100 and $ 150, it could even be much cheaper when making production mass. Basically, we could have a screen at an affordable price for all visually impaired and deafblind people.
My project is open source. The idea is to make available to anyone anywhere in the world a code that can be modified and improved, files for 3D printers to print their parts and an assembly manual, so that anyone can download, print, assemble and use
Its development is based on an esp32 microcontroller. (What is open source hardware)
I do this because I am looking for support if you can support or meet someone who can support with the following needs:
Microcontroller Programmer
Diceño in 3d
Handling the HiD protocol (we need to create the code for the Esp-32 to communicate with the breille HID)
Language translator
Documentation development
Economical support
Any company or organization that finances the project.
If you can support some of these needs or know someone who can do it or an organization that can financially finance the project, I would be very grateful if you could contact me at +584129994784
OUR REPOSITORY
https://github.com/brailletouch/brailletouch
peter jansen wrote 06/16/2018 at 07:54 • point
This is really interesting.  Does this mean it's possible to have the ESP32 both connected to one network, while broadcasting it's own network at the same time?   Would it be possible to use the ESP32 as a pass-through bridge for [device] -> ESP32 -> WiFi network, allowing the device to access both normal traffic on the WiFi network, as well as the ESP32's own internal page?  The reason I ask is that iPhones are notoriously difficult to connect external devices to, especially if they require high-bandwidth.  One of the things I've been exploring is connecting the iPhone to a device that poses as a wifi access point that allows normal wifi access, but also is able to serve it's own data to the device (either through an app, or just presenting a webpage through safari).  But it's not entirely clear to me that this is easily done with an ESP32 -- I've been investigating using a Pi Zero W with a second wifi dongle over USB, but it's a lot of extra space/power.
Tony wrote 06/17/2018 at 14:54 • point
Absolutely yes it is possible to have an ESP32 both connected to a network while broadcasting its own wifi. However, since there's only one radio both have to run on the same channel for this to work.
With the SDK, it's done automatically: broadcasted wifi will automatically tuned to connected wifi channel if they are different.
What you're asking to do would be some kind of low level routing. Pretty sure it's possible, but I don't know the inner working of it.
peter jansen wrote 06/18/2018 at 05:06 • point
That's really interesting -- thanks for the information!   I'll have to read more into this -- I've mostly been tinkering with the Arduino implementation for ESP32, but it sounds like going under the hood might offer some impressive capabilities.
Straight forward Info screen utilizing WiFi of an ESP32 and 7 Color ePaper technology
Project Owner Contributor
ReadMePaper
kc1r74pkc1r74p
Educational sumorobots with ESP32
SumoESP
lauri-vsandiLauri Võsandi
Run a WebServer on ESP32, which can be accessed on the IP address of the ESP32. Access the page with IP address, Local Domain or even Cloud!
WebServers on ESP32
akarshagarwal98akarshagarwal98
FM transmitter utilizing the QN8066, remotely controlled via ESP32 Wi-Fi with Access Point functionality
FM Transmitter controlled by ESP32 via Wi-Fi
ricardo-lima-carattiRicardo Lima Caratti
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "esp32-wifi-manager", please tell us the reason.
Send message
Remove Member
