6WD all terrain robot
This is ongoing project of the mobile robot that can move and collect data in rough terrain
The main goal of this project is to build a 6WD mobile robot capable of moving and collect data in rough terrain. Such a robot could be used to patrol the surroundings around your house, company or hard to reach and hazardous places. Thanks to the image from the fpv camera you can control the robot even if it is out of sight. This feature allows the robot operator to perform remote inspection tasks in areas that are difficult to access or are dangerous for humans. Robot parameters : - External dimensions (LxWxH): 405x340x220 mm (robot prepared for transport) - Total weight: 7 kg - Ground clearance: 45 mm - 4DOF manipulator - 3 cameras: 2x FPV, 1x WiFi
Examples of applications:
  • protection of facilities and areas against the access of unauthorized persons
  • exploration and inspection of hard to reach places
    • tunnels and pipes
  • inspection of dangerous places for human life and health
    • chemically contaminated places
    • buildings threatening to collapse
  • transport and neutralization of dangerous objects (explosives, harmful and toxic chemicals)
Example problem and its solution
Formulation of the problem:
Currently a classic monitoring and protection system use of stationary cameras that monitor only the part of the area that should be protected. This disadvantage causes that the system is incomplete and provides only partial control over what is happening in the protected area. Additionally, the camera itself usually does not have the ability to monitor environmental parameters.
Solution to the problem:
The solution to the problem formulated above is a camera placed on a remotely controlled or autonomous vehicle. Such a vehicle can reach every corner of a protected area and give us a real-time preview if everything is okay. It can also send measurement data of physical quantities (e.g. gases, temperatures) to the base station. Furthermore, the transmitted image is processed to detect moving objects with specific features in the selected protected zone. If such objects appear then the system will send an emergency notification to the owner or security office.
The main controller in this electronic system is Arduino Mega 2560. To be able to control six motors I used two BTS7960B Motor Drivers (H-Bridges). Three motors on each side are connected to one motor driver. Each of the Motor Driver can be loaded by the current up to 43A that gives a sufficient margin of power even for the mobile robot moving over rough terrain. The electronic system is equipped with two power sources. One for supplying the DC motors and servos (LiPo battery 11.1V, 5500 mAh) and the other to supply Arduino, wifi module, fpv camera and sensors (LiPo battery 11.1V, 5500 mAh).
  • 6 × DC 12V 180RPM High Torque Gear Reducer Motor https://goo.gl/UtnKRi
  • 2 × Wheel Rim & Tires HSP 1:10 Monster Truck https://goo.gl/vtCiwX
  • 2 × Lipo Battery 11.1V, 5500mAh https://goo.gl/N3tUf9
  • 6 × Hex DC Gear Motor Connector https://goo.gl/ULGAob
  • 4 × CJMCU-VL53L0X Laser ToF Time-of-Flight Ranging Sensor https://goo.gl/PpStN2
View all 11 components
View all 13 project logs
seilerjacinda925 wrote 11/19/2019 at 15:39 point
Hi
Nice to meet you after viewing your profile i am Jacinda, from (jakarta) indonesia,
i have a project discussion with you please email me on: (jacinda.seiler@yahoo.com)
Dr.Root wrote 08/19/2018 at 13:35 point
hi . nice build! . i want source code , how give me source code ?
email : hosein.naamdari@gmail.com
Vishnu Mohanan wrote 03/24/2018 at 16:00 point
Nice build! Do those wheels have metal or plastic rims ?
codersilver wrote 05/16/2018 at 21:45 point
Thx, as so-far these are plastic rims but they are quite durable.
