The first tests of 6WD robot
A project log for 6WD all terrain robot
This is ongoing project of the mobile robot that can move and collect data in rough terrain
codersilvercodersilver 12/28/2017 at 19:200 Comments
The above video shows the first tests of 6WD robot in my room. This robot is able to carry a load of several kilos very easily, on the video it transports 8 bottles of water equivalent to 12 kg. The robot can also easily overcome various obstacles encountered on its way. The speed of the robot is regulated in its full range via a 2.4 GHz transmitter
The parts needed:
1. DC 12V 180RPM High Torque Gear Reducer Motor - https://goo.gl/UtnKRi
2. Tires HSP 1:10 Monster Truck - https://goo.gl/vtCiwX
3. Arduino mega 2560 - https://goo.gl/G5MxXs
4. VL53L0X Laser ToF Sensor - https://goo.gl/PpStN2
5. 5500mAh 3S 45C Lipo Battery -- https://goo.gl/N3tUf9
6. Stainless Steel Power Push Button Switch - https://goo.gl/ScvF9J
Control:
1. FrSky TARANIS Q X7 2.4GHz 7CH Transmitter - https://goo.gl/3JhLwe
2. FlySky FS 2.4GHz 6 CH Receiver - https://goo.gl/afmiPq
