close-circle
CO2 blown Cellulose Acetate Polymer Extruder
Designing and building a cellulose acetate (or some similar renewable polymer) extruder, with foam die and CO2 blowing agent
close
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Not an extruder for 3D printing, but for making foam sheet.
Looking to use supercritical CO2.
Currently researching casting/milling methods- seems most appropriate to cast a rough shape with the blades then mill it rather than milling a cylinder down. Willing to build a vacuum chamber for the casting.
I did notice screws can break under the pressure & temperature gradients involved in extrusion.
Will first have search literature for optimal blade design. I noticed a lapsed Japanese patent describing the particular foam I want to produce. I've been researching this for a year or so now, but other projects come first.
