core51822 breadboarding
A project log for Bluetooth Gamepad Phone Case
A bluetooth gamepad integrated into a phone case.
maaveMaave 12/21/2017 at 21:411 Comment
Unfortunately the core51822 modules use a 2.00mm (0.787") pitch rather than regular breadboard 0.1" (2.54mm). It's double row (2x9 pin) as well which makes DIY adapters more difficult.
There are a couple solution.
edit: after using it for a few days my 0.1" jumpers have failed. Scratch that method. I've instead swapped some headers with an inch of 24 AWG wire. More attempts to come later.
Peter Windridge wrote 02/16/2020 at 11:59 point
Hi, old post but I got a few boards made up for a remote control project- uses a standard 2mm pitch connect from RS ( https://uk.rs-online.com/web/p/pcb-sockets/7644648/ )  components.  If you're in the UK I can post at cost- details https://peter.windridge.org.uk/home/bike-handlebar-bluetooth-remote-control-for-phone-navigation-and-music .  Might be suitable for game pad with some bodging.
