Firmware development 1
A project log for Hydroponics control
Automated control of hydroponics Garden with Control Via Blynk
saabmanSaabman 11/17/2017 at 23:280 Comments
Now I have the IO sorted out time to move onto making the firmware come together.
The basic frame work.
Read All   the sensor values  -
Send Values to Blynk App.
If Moisture is low - Turn on the Pump for 6 minutes (the length of time it takes to flood the bed)
If Temp is above X level  - Turn on fans
If Humid is below Y level - Turn on mister for 1 minute (this is an arbitrary value and will need tuning)
If WaterLevel is low - Set an Alert on the Blynk App.
Set points to be adjusted by Blynk
Temperature and Humidity readings displayed on the Blynk App
