Electronics schematics
A project log for Fully Automated Nutrient Film Hydroponics
Nutrient Film (NF) Technique hydroponics system you can build up and leave unattended
viljam-lngViljam Lång 08/22/2014 at 10:220 Comments
Connectivity schematics for the electronics (with device codes from the process schematic) below. "UDOO" is a tiny PC with embedded arduino due, although I'll be using a separate due board. "Volt. div." is a voltage divider circuit for matching the sensor output to the ADC voltage limits, and "Instr. amp." is an instrumentation amplifier. "Q1"--"Q9" refer to switches, most likely power MOSFETs. Dashed line shows the individual boards; I'll place the pressure sensors (i.e. water level sensors) on the board in order to have the amplification as close to the sensors as possible. I'll make the final schematic with eagle once I've chosen the components. Next-up: Software
