Software published on Github
A project log for Paperworker
The paperworker project is a simple and cheap paper document scanning solution to handle all of my incoming paperwork.
enkiEnki 04/22/2019 at 20:140 Comments
Scanner frontend scripts, systemd units and other stuff has been published on Github. The setup can be performed using Ansible with an example setup described in the README.md file
https://github.com/mgrela/inbox
