Thermal Superconf 2017 Badge
Turn the 2017 Superconf bage into a mediocre thermal camera
Add a panasonic grideye thermal camera to the 2017 Hackday Superconference badge and make it a Flir One or Flir C2 competitor that can combine the thermal camera and visible camaera into one image. Unfortunately the thermal camera resolution is 8x8 and the visible camera is turned to one bit per pixel 128x64 in the process. The results are best described as "actually working"
Mike Szczys wrote 11/17/2017 at 22:00 point
Woot! I loved this hack. Any chance you can post up some video? It's much more impressive when you see it in action!
