Breakout on ARM7 LPC2148
An implementation of "Breakout" game, originally developed by 'Atari' in 1976
We are porting the original game on our 32-bit ARM7 board. We are using a 128x64 glcd. The game has some bricks placed horizontally on upper part of the screen. On the lower part is a paddle. The paddle can move left and right and is controlled by the user. A ball moves across the screen bouncing off the top and side walls of the screen. When a brick is hit, the ball bounces off and the brick vanishes. The player looses half the points when the ball touches the bottom of the screen. The ball can touch the ground 4 times before the game gets over.
The paddle has three parts: left, center, right. If the ball strikes left side of paddle, it gets reflected towards left side and similarly for right side. For center of paddle, the ball moves vertically without any angle.
There are some bomb bricks. If the ball hits bomb brick, it explodes upto 8 bricks in it's vicinity.
There are 2 points for normal brick, 10 points for bomb bricks.
Note that the welcome splash screen logo belongs to old skull games(http://www.oldskullgames.net/) and is taken purely for educational purposes.
Game video can be watched on youtube :
The implementation details can be found at the following link:
https://drive.google.com/file/d/1OTkWtELIhaZhcP6rbQO4PeHm7wvM4U1b/view?usp=sharing
_glcd_graphics.h
It implements the glcd interfacing and graphics routines
plain - 10.64 kB - 11/30/2017 at 17:46
Download
character_map.h
It stores the character maps for variable width tahoma font.
plain - 28.14 kB - 11/29/2017 at 11:51
Download
timer.h
It implements precise timer accurate upto 1 us.
plain - 2.30 kB - 11/29/2017 at 11:51
Download
images.h
It stores the monochrome bitmap arrays for splash images.
plain - 20.88 kB - 11/29/2017 at 11:51
Download
game_logic.c
It implements the game logic.
plain - 9.73 kB - 11/29/2017 at 11:51
Download
View all 6 files
  • 1 × ngx lpc2148 board Arm7 board
  • 1 × USB A to B cable
  • 1 × 128x64 GLCD
  • 1 × Two tactile switches
  • 2 × 10K pullup resistor for switches
View all 11 components
  • Progress as on 18 Nov 2017
    gaurav sharma11/19/2017 at 07:41 0 comments
    Connected the glcd, two switches to the micro controller board.
    Attached a 10K potentiometer to set contrast on glcd.
    Implemented a timer(using builtin hardware timers) for precise timings correct to 1 microsecond.
    Initialized the GLCD using commands from GLCD datasheet.
    Implemented functions to set and clear pixels at arbitrary coordinates on the glcd.
    Tested the user input through buttons and all other connections.
View project log
Devesh Samaiya wrote 12/03/2017 at 20:18 point
Beautiful.
gaurav sharma wrote 12/04/2017 at 12:18 point
Thank you sir.
Himanshu Shekhar wrote 12/04/2017 at 12:31 point
Thanks Sir !   It's quite encouraging and motivating to have appreciation from YOU
