So once I identified the analog pins, it worked out perfectly because they're exposed on the front (camera side) of the badge. I soldered in the Spectra ThinPot 50mm 10K. While the three I needed are right in a row, they're not in the right order so I had to cross one over (thus the electrical tape insulation).
