Testing out an idea that while printing, the nozzle can be pressed in to the job at various points to fuse together or "spot weld" the layers and increase overall part strength.<br><br>Result: About 20% improved strength<br><br>Print Spreed: 60mm/s<br>Layer height: 0.3mm<br>Part height: 100mm<br>Part width: 15mm<br><br>4 spot welds, one in each corner.<br>The nozzle pressed in by 0.3mm for 0.2 seconds.<br><br>See it in action over at youtube <a target="_blank" rel="noopener noreferrer" href="https://youtu.be/Om2sPvlqiZs">https://youtu.be/Om2sPvlqiZs</a><br><br>You can find the script/code over at my github <a target="_blank" rel="noopener noreferrer" href="https://github.com/boy1dr/fdm_spot_welded_layers">https://github.com/boy1dr/fdm_spot_welded_layers</a><br>Feel free to mess around with it, perhaps one day this will show up in a slicer :)
