• Retroengineering an ultrasound probe - part 1/X
    kelu1242 days ago 0 comments
    I just got an interesting mechanical probe, a Bard Site Rite - piezo at 7.5MHz. The plug is quite simple, and digging into the cable yields 2 pairs of cable, one coax, a bigger cable with two "big" cables. I've made sure it's a mechanical probe. The aim is to try and see if I can connect it to my board and get an image.
    Good point for this probe is that it unscrews nicely.
    and even better, it has changeable heads!
    I assume two pairs of cables are for motors / actuators, coax is for the signal coming back (hence the bead). But how can I see that on the pins above?
    Going to search for the reference manual and other resources. I'd rather not unscrew the head yet!
    To be continued... possibly with a corresponding patent... Electromagnets?
  • Progressing with the signal acquisitions
    kelu12402/27/2018 at 22:07 0 comments
    Some good news again =)
    I got to better control pulses (I need to really read more carefully  datasheets), got acquisitions at 64Msps, really looking good, and got some (badly formed at the moment) images!
    Acquisitions - going to specs at 64Msps. Thanks David =)
    Pulser: getting 200ns wide 75V pulses (blue is the pulse with a piezo on, in yellow is the 'damping' control signal.
    Getting some images from a "damaged" probe
    More on the log!
  • Getting great results
    kelu12402/24/2018 at 19:43 3 comments
    That's moving forward! I'm getting some results with the following setup - using a piezo with a fixed distance, and a pulser at 25V.
    Getting nice echoes (x-label in us)
    The gain control works as well =)
    and the FFT looks relatively clean!
  • More hacks
    kelu12402/11/2018 at 22:47 0 comments
    I needed to replace some elements, some stuff is erratic, but hey, I've been able to set up all registers, run the analog part, and control the DAC gain.  I (just) need to run the ADC now, the fpga still thinks s.he's not working ;)
    Some pulse control works, and pulses too! With a 10x probe, on a 25V pulse
    Next step.. digitalization. More on the log.
  • Further tests
    kelu12401/26/2018 at 20:23 0 comments
    The clock had to be removed!
    Investigation showed no connection through USB.. a ftdi issue. Powers were OK.. but still nothing.
    So what? Clock!!
    I unfortunately destroyed the 12MHz clock.. well that's it =) I'll be waiting for the new one from digikey.
    The clock has to be rotated by 90°
    More on the next session !
  • Let's have a first peek
    kelu12401/26/2018 at 20:16 2 comments
    This has reached a couple of days ago =)
    Looks good - ice40 and ram look good. The high-level pulser footprint seems reversed. The 3.3V is on, 5V level looks good, seems good!
