Easier to use: USB only, and VGA output.
A project log for un0rick - an ice40 ultrasound board
A hx4k lattice fpga based pulse echo board, yosys compatible
kelu124kelu124 04/06/2021 at 11:080 Comments
Long story short, the board does pulse echo in live, can output to host via USB, with visualisation through a VGA connector.
You can read more on the website
lit3-32
Also.. the pHAT version is coming up, with moar gain !
