Electronic Dice
A set of smart dice, the same size as traditional ones, full of LEDs and Bluetooth-enabled.
Public Chat
A set of 'electronically augmented' dice. Completely customizable, they can be used as a drop-in replacement for regular dice, and are configured via bluetooth. They can also be used to keep track of all your rolls, direct your phone to play sound effects, or even used to play DnD online.
I am creating a set of electronically augmented dice. They light up all different colors, know which way they roll and are configurable with an app on your phone. The electronic dice are the same size as regular polyhedral playing dice and are meant to be used as a drop in replacement in your favorite board or role-playing games.
They feel just like regular dice, thanks to their unique construction and features, are incredibly strong and in fact waterproof.
Although I currently only have a D6 and D20 prototyped, I plan on offering a full DnD set when the project is ready for crowdfunding.
The dice use a bluetooth microcontroller, an accelerometer and RGB leds soldered onto a flexible PCB that is then folded into the the polyhedral shape of each die. On top of that, they include a rechargeable battery and small coil for wireless inductive charging.
Although the primary purpose of the dice is to add fun visuals to your existing games, you will have the opportunity to take full advantage of all the integrated tech, should you want to. From keeping track of your stats to accessibility or online roll playing integrations, there is a wealth of possibilities associated with these little devices once you connect them to your phone or computer.
The dice have already been presented at both the Maker Faire and Gen Con to incredible receptions, and so I am now working on trying to bring them to life!
D20 Layout Bottom.pdf
D20 PCB Layout, bottom
Adobe Portable Document Format - 76.30 kB - 09/30/2019 at 14:02
Preview
Download
D20 Layout Top.pdf
D20 PCB Layout, top
Adobe Portable Document Format - 129.79 kB - 09/30/2019 at 14:02
Preview
Download
D20v4.pdf
D20 prototype using new nrf52810 microcontroller.
Adobe Portable Document Format - 261.63 kB - 09/28/2019 at 17:34
Preview
Download
Dice V3RevC PCB Bot.pdf
Next revision of the Dice. Bottom of Flexible PCB
Adobe Portable Document Format - 73.77 kB - 03/01/2018 at 17:17
Preview
Download
Dice V3RevC Schematic.pdf
Next revision of the Dice. Schematics
Adobe Portable Document Format - 270.04 kB - 03/01/2018 at 17:17
Preview
Download
View all 9 files
  • 1 × MCP73831T-2ATI/OT Linear Battery Charger Controller Li-Ion/Li-Pol 15mA to 500mA 4.2V
  • 1 × MIC2095-1YMT-TR Power Distribution Switch
  • 1 × AS-10100-60-113 Lipo Battery, 60mAh
  • 1 × TDXKTL8 10mm 7uH wireless charging coil
  • 1 × BU52272NUZ-ZE2 Omnipolar Hall Effect Sensor,
View all 12 components
  • Dice Assembly
    Jean Simonet11/05/2019 at 01:02 6 comments
    I put together a short video of how I assemble a die, for anyone who's interested!
    Here are the steps shown in the video, and some notes to go along:
  • Light and Dark Mode...
    Jean Simonet09/30/2019 at 14:41 5 comments
    Hey there!
    A quick update with pictures of the updated D20. I am testing different combinations of materials and silkscreen colors for the dice.
    The challenge here is to find a combination that diffuses the light nicely, without blocking most of it out and still looking interesting when off.
  • Prototype 4
    Jean Simonet08/25/2019 at 00:19 0 comments
    Hello again friends! It's finally time for an update on the Electronic dice. I just returned from showing the latest version at Gen Con, and it was fantastic! So, what's new?
    Well, first and foremost, the new prototype is of a D20! Still regular size, still full of LEDs, still inductively charged, and still awesome. In fact, I think the D20 is by far the most fun light up die. There are, however, several other differences with previous prototypes.
  • Prototype 3
    Jean Simonet07/02/2018 at 17:03 6 comments
    This is the next revision of the Electronic Dice. I've spent a lot of time putting it together, and it is really coming along!
    Looks pretty nice, doesn't it?
    So first things first, this version is exactly 16mm, the same size as a regular dice. And as you can see here next to the previous prototype, it is also more rounded. It's amazing how much difference 1mm can make, both in how the dice feels in your hand, and how much harder it is to put together!
  • RGB Dice prototype
    Jean Simonet02/04/2018 at 22:47 1 comment
    Hey all,
    I finally finished the second board for the Dice, the full RGB one this time! It's pretty awesome already! I don't have a flexible PCB version yet, but this here is a prototype board.
    Those APA102 2x2mm look really awesome!
  • Tiny Lipo Batteries
    Jean Simonet12/29/2017 at 19:52 0 comments
    Following a suggestion from a commenter on youtube, I was able to find a lipo battery small enough to fit in the dice! I received samples early this week, very exciting!
    Lipo next to current battery (non-rechargeable lithium)
    I got so excited to start seeing if I could make the next version only 16mm wide that I started working on the schematics and now 3D CAD. That's just as well, since now I can get prototype boards made while I continue to work on the firmware.
  • Twitch streaming
    Jean Simonet12/20/2017 at 22:07 0 comments
    Going to do some streaming in just a bit, stop on by if you like! http://twitch.tv/jean_simonet
  • A shorter presentation video!
    Jean Simonet12/01/2017 at 00:25 0 comments
    I put together a shorter video, less technical and more like a sizzle-reel.
    Hopefully I can get back to work soon! Taking pictures and editing stuff together, let alone re-recording stuff a gazillion times, ends up sucking up soooo much time...
    Anyhow, hope you all like it,
    Cheers!
View all 8 project logs
Dmitry Kabak wrote 01/28/2020 at 12:19 point
Excellent work, and a nice landing! I love your project so much, and will definitely buy some! (and re-program them, muhaha). I've made some of my own, with nrf52 and leds, but they are HUGE and not too much throwable. So I just enjoy your engineering skills, and desire to make this project a finished product!
Maximilian Laurenz wrote 12/10/2019 at 16:58 point
Have you seen this project?
https://www.kickstarter.com/projects/1928372437/godice-your-favorite-dice-games-reimagined
It's a simpler design without the LEDs, but I like the idea with the shells to convert the D6 into another die.
Hexastorm wrote 12/12/2019 at 08:41 point
Very good pick... Looked at their timeline.. they started in june 2019 which seems incredibly fast. If I look at the videos.. i am not sure if they really have a working dice, let alone a balanced one. They did produce the gocube so I assume they r up to the task or might have a working one.
Michał wrote 10/13/2019 at 12:04 point
Pro level. Congrats!
Peter Smith wrote 10/03/2019 at 05:03 point
Any chance you can publish the Bluetooth specs? (I write Bluetooth-control apps for the Windows store, and I'd love to support these)!
Jean Simonet wrote 10/03/2019 at 13:35 point
I most definitely will! You could technically infer the specs right now from the code on github, but that'll be a bit painful. At some point I'll extract it out into a nice document.
crjeder wrote 01/12/2018 at 14:33 point
They look amazing!
Are those dice stil fair? Or do the most of the time show e. g. the face on the top of the battery?
Jean Simonet wrote 02/04/2018 at 22:59 point
Sorry for not replying sooner. The current version is pretty poorly balanced, and I can tell you that with perfect certainty, as I can record every single throw. :) The 4 face comes up about 15% more than any other...
I have several plans of attack to make the next version fair. For starter, I am getting rid of the screws, and making sure the battery is centered. But I also will be able to cut little strips of sticky lead tape (used for golf clubs I think) and stick them on the board or case where they need to go. It'll be hard to know where that is until I have the first *new* die assembled, but I think it'll work!
Juan Rial wrote 09/12/2019 at 09:44 point
I wonder how difficult it would be to build a miniature version of those machines they use at tyre shops to balance your wheels? That would drastically cut down on the time required to balance them.
How do they balance commercial dice anyway? I can hardly believe those are balanced by tossing them a couple thousand times and recording the results each time. ;)
Bastiaan wrote 12/06/2017 at 18:45 point
This is a really awesome project and I enjoyed your video. You talked about looking for rechargeable batteries that fit the requirements, have you looked at super capacitors? There should be ones with a decent capacity at the size of the battery you are using and will keep components to charge it to a minimum. Maybe it won't fit the energy requirements you have, especially with Bluetooth and RGB LEDs but they store some decent amount of energy. Also, wireless charging would be really great, but that's even more parts in there ...
Jean Simonet wrote 02/04/2018 at 23:00 point
I was eventually able to source some properly sized LiPo batteries (See project log). Thanks for the suggestion though!
Bastiaan wrote 02/04/2018 at 23:20 point
Just read your new log on the RGB version, I'm really impressed. The original ones already cramped in a lot of stuff, and this just takes that a step further. Great to see them coming along! :) I'm going to look at those APA102 LEDs, they seem interesting.
Guy Carver wrote 11/29/2017 at 17:38 point
Pretty damn cool Jean.
Jean Simonet wrote 11/30/2017 at 05:38 point
Ah! Thanks boss! ;)
Chris wrote 11/29/2017 at 04:25 point
You could use a coin battery with an external recharger for the time unless you actually want it to be completely self-contained.
Great work! ヽ(´▽`)/
 I love the integration and since I'm a dice lover I really want some of them!
Jean Simonet wrote 11/30/2017 at 05:41 point
Thanks! I'd love to get to the point where I can offer you some ;)
