Acrylic Assembly
A project log for DiamondLight
Light made from salvage acrylic & LED
stanislas-bertrandStanislas Bertrand 04/12/2018 at 18:560 Comments
The assembly of the DiamondLight starts with the 6 feet made of 4, 6mm rings and a rubber pad. The base is 10mm thick with cutout slots for the cable and adjustment for the U bracket screws.
Base Assembly
Base Assembly
The U brackets are mounted on the base with screw and nylon washers.
Base with brackets
Base with brackets
Assembly of a panel requires the following. The standoff are embedded in the acrylic, hex cutout were made with the laser. The side cover have minor horizontal adjustment thanks to 4mm long slot holes. Painter tape covers the acrylic for protection during preparation. The outside edge of the main acrylic piece were sanded to smooth light diffusion. The LED assembly was completed on a support to get the required position and angle.
Panel Elements
Panel Elements
First assembled panel. Peeling off the painter's tape is a careful task. The side cover is only 2mm thick acrylic.
Assembled Panel
Assembled Panel
After one done, 2 more to go. All 3 panel assembled.
DiamondLight Panels
DiamondLight Panels
The panel is mounted on the base. The cable is passed thru the hole in the U-bracket. Screw secures the panel on the base. The panel has slot holes on the bottom and the top to allows for adjustment.
Panel Mount
Panel Mount
All the panels are mounted on the base. The top plate is assemble with its U-brackets and completes the DiamondLight.
DiamondLight
DiamondLight
