LED PCB Strip Assembly
A project log for DiamondLight
Light made from salvage acrylic & LED
stanislas-bertrandStanislas Bertrand 08/06/2018 at 01:150 Comments
The LED PCB strips assembly consist to solder and test the 4 white and 5 RGB LED. The DiamondLight design uses 24 strips. Overall I have assembled 105 strips across the different project.
The set of 4 strips took around 30 to 45 min to assemble and test.
